No endpoints when adding Somfy RTS Centralis box to Zipabox
Willem Hoeve shared this question 10 years ago
To make my sunscreen remote controlled I added a Somfy Centralis RTS box. My sunscreen has a conventional (non RTS) motor. By adding the Somfy Centralis RTS box I can add it to the Zipabox. It is recognized by the Zipabox but there are no endpoints detected. I think the reason for this is that the sunscreen has mechanical endpoints.
Because of this I cannot control the sunscreen with the Zipabox. Is there a way to solve this? Is it possible to add virtual endpoints so that I can control the screen? (the screen will stop automatically because of the mechanical endpoints). I can control the screen with a somfy remote control (telis 4).
Any help or ideas would be appreciated.
Thanks in advance.
First of all, if you did not, you should upgrade to the latest beta release of zipabox firmware.
Then try to re-add your device.
Dear Zeljko,
Upgrading the box to the latest beta release did the trick! After re-adding the Somfy Centralis RTS device I was able to configure the settings. Everything is working fine now.
Thanks for your swift reply.
Kind regards,
Willem Hoeve
Zaandijk
The Netherlands
