Zipabox LED on/off
christophe brachet shared this question 13 years ago
hi , I can't change (since one month)status of Zipabox LED , because hidden !! it's normal ??
Have you checked under general settings/Zipabox settings?
Yes ... But i don't know where i can do modification ... Hidden or not .
Don't think you can...
I would like to be able to use the two buttons (button 1 and 2 on ZipaBox), but same thing there.
They are locked and hidden.
and for the buttons I see no reason to lock them unusable.
We plan to use them in the near future for some functionality. For example, you will be able to enter you PIN by pressing the button 1 multiple times and than disarm the system in case something is wrong with you keypad, z-wave network, someone lost the keyfob or anything else. Also, you will be able to use them as a panic button. So if we allow users to make their own programming options, we will lose reliability of the system and those two buttons representing the "last line of defense" if everything else go wrong.
For all those other issues (which are not mission critical), you can always use any z-wave switch...
Ok ....
But in one of my "scène " .... There is Green Led Which turn on .... And now , i can't delete it !! Can you do this for ?
