Send motion off after setting - less than one minute?
Claus shared this question 10 years ago
I have an alarm setup where every time I arm my alarm I either have to wait for my closest motion sensor to send the motion off signal to the controller or suffer the immediate triggering of the alarm after arming it. The setting is set to 1 (minute). My question is if there is a way to set it to less than a minute for the sensor in question or if there is a way I can override that particular sensor when arming the alarm
Hi, see the attached printscreens. Go to the alarm, open the settings for the specific zone (sensor) and check bypass allowed and remove bypass.
Now you should be able to alarm the system without waiting the sensor to change state.
