Chacon Roller Shutter default icon ???
Hello All,
I've install lot off Roller Shutter Chacon all works fine.
But i've a question it's possible to have other icon for the fonction.
Actually we have level 0 to 100 and if choose other like 50 the roller blocked and after it's not possible to change the statu.
I've to desinstall and reinstall it.
It's possible to change the icon to have ON / OFF function??
Thanks for your feedback.
BR.
What software is your Zipabox running?
My Last Firmware is 8w
Try to open the actual device setting and change the type to a switch.
Ok but try to put what type of device???
I've test shutter and blind.
I don't test on/off function.
Did you have any chacon in your installation?
No, I dont. I§m just thinking if you want on off function you might need to simply change the device type to som on off switch or something and try to see if this solves your problem.
