Foscam FI9900EP
Christoph Krieger shared this problem 10 years ago
In Progress
Video is not working after successfull integration
"201, Unable to load stream or clip file, connection failed."
Snapshot works. The stream does work, when I open the adress with VLC
Dear Christoph,
Please try to change your IP adress with 10.0.0.1 in High quality stream path.
Dont forget to save->sync->reload page.
*Also in IP camera configuration page choose H.264 as default.
Let us know, if the issue still perist.
Pero Zovkic
Dear Pero.
Did you mean only in the settings of the cam in the web interface? How should that work? Of course I have tried but with no success.
I can not change my whole IP range as I run several server. Would take me a week to adjust everything else.
Christoph
Hello!
Is the Foscam FI9900p fully supported by the Zipabox?
