New to Zipato
Vimal shared this question 10 years ago
I am new to Zipato/Zipatile. I recently purchased the Zipatile and have fibaro dimmer. I managed to connect to my living room pendant light and have the switch working it. But when i dim via the zipatile-say to 50% and then turn off the light via the switch and turn it back on it comes back to 50%. I want the switch to turn it back to 100%. Basically i want the switch to turn it on (100%) and off & dim via the Zipatile. Please can any help me on what parameter am i not setting right? Thanks.
Sorry forgot to mention-Fibaro is a FGD211V2.1
I dont think this is possible. Having looked at the manual it seems that the only option you have is to use parameters for double clicking (15 = 1) and 6 = 2.
I might be wrong though.
Dear Vimal,
In case you missed there is workaround in device manual (Controlling the Dimmer 2 using a switch):
Turning the light ON completely: fast double-click switch no. 1. The Dimmer 2 will set the load at 99%.
It is necessery for this case that switch type is "Momentary switch" in device configuration.
Pero Zovkic
Thanks Attila & Pero for your replies.
But i dont see any of these options in the Zipatile. On the configuration tab, i cant even set it as a momentary switch. Are you guys talking about the options on Fibaro's home centre?Apologies, this is my first time with Zipatile. I have attached few screenshots.
Thanks,
Vimal
Check sending to group 1 (parameter 6) to 2 and double click to enabled. What Pero was referring to is that you will need to use monostable switch (bell button) not bi-stable switch rocket switch.
Also parameter switch type needs to be changed.
