Local Connection Lost After Some Period of Time
Cemal AKARSU shared this problem 10 years ago
I have tried the local connection with two different Zipabox and I have seen a problem. Details of this issue are listed below:
* I can see Zipabox in the local connection list and I can connect to it using login information via my Android Phone.
* If I open another application such as Facebook in my phone and then turn back to Zipato mobile Application it gives me the following error:
" Device cannot communicate properly with the server or Zipabox"
* In order to re-control Zipabox I have to log out and log in again.
What can be the reason for that problem and how can I solve it?
Regards,
Cemal
i used to have this issue, with current firmware and non beta app. Newest beta firmware and beta app no problem.
Thanks Adrian. My problem has been solved with the same way.
when you are working with app in local mode, if you close app with Home button and then reopen the app you can work it with out any problem.
but if you close app with return button, when you reopen the app it does n't work and you should log in again.
