How to run a rule within the Zipato mobile app
Christoph shared this question 10 years ago
Hi all,
I have the Zipatile and made a rule, that some stuff happens when I press one of the buttons on the zipatile. So far so good. Now I'd like to run this rule also from the zipato mobile app.
How can I do that? Is there something like a "virtual switch" like power switchs I can hit on/off in the app and run a selected rule with that? How can I get there? :)
Thanks.
KlyX
Set up a rule on Web app that will trigger when the virtual switches state changes.
yes, make the zipatile button activate the virtual switch instead of the actual rule itself. The virtual switch will then activate the rule, this way you can use a switch in your normal menu on a phone/tablet, but also trigger the rule via other rules if need be.
