Combine two scheduler in the same rule ?
domoteek shared this question 13 years ago
Is there a way to use two scheduler in the same rule ?
Fore example :
When Monday, Tuesday, Wednesday, Thursday and Friday At 8:00
AND Sturday and synday at 10:00
Then do somtehing...
I can clearly make two rules for this example but if i want tou user a complicated scheduler it would be easier and lighter to use one and only rule with several scheduler than several ruls with one different scheduler in each rule.
So Is there a way to do that ?
Yes you can combine two or more schedulers (you must use 'OR' operators).
For example:
glsR8mv7r2A4u8o5TuVv
Yeaah that's great !
Thank you !
