set target temperature of virtual thermostat via api
Peter wunderink shared this question 10 years ago
hi
I like to set the target temperature of a virtual thermostat via an url. is this posible. and if so: how ?
You can make it through a virtual meter or virtual thermometer.
There you set the desired temperature on the url.
Then you create a rule.
When: virtual meters
Then: set-temperature / virtual thermostat - Set to - temperature (virtual meter)
