st814 no humidity trigger in rule creator
Kenneth Møller shared this problem 10 years ago
Not a Problem
Hi.
I just bought an everspring ST-814 temp/humidity sensor to work on my bathroom (start power to the fan when the humidity rises)
In device manager, I can seemingly configure trigger values both for temperature and humidity (when the sensor is supposed to report to the zipabox) however, in rule-creator, I can only find the Temperature trigger control. - I can't find the humidity trigger at all.
any takes on this? (the FW is 0.9.999.8w)
Usually for these type of sensors you have to use the "METER" puzzles and operators to make the condition you want. i.e.
WHEN Temperature > 25
ACTION Turn ON Fan
The settings you are talking about only change how often update the sensor/meter status in the zipabox. See attached rule I have for turning ON a light when motion is detected and luminance meter is below 30 lux.
