"No Endpoints" (still) when adding Oregon sensors
I purchased 2 new Oregon THGR810 sensors. They are discovered but it shows "No Endpoints" in the device manager. I get no tem and humidty.
Thus, exactly the same problem as the user in this thread
https://community.zipato.com/topic/no-endpoints-when-adding-oregeon-sensors
I have spent 2 hours rebooting, refreshing excluding and including and whatever but still "No Endpoints"...
So the problem is NOT solved as that previous thread is marked.
Please help - I need those sensors
Mats
I
Which firmware is your box running?
The box is running firmware 0.9.999.8a
Mats
Mats
Update to latest FW?
Yes, you should upgrade and it should resolve your Oregon problem.
However, latest beta is not good for receiver 433 devices. The bug was introduced in that beta release while trying to resolve some other problem and the discovery for receivers won't work.
If you need to join some receivers before new beta is released, I suggest you to upgrade and open a ticket to support. They will put the correction for receivers on your box.
Hi ZeljkoSlightly confusing answer - you say I should upgrade byt the UI says that FW 0.9.999.8a is "up to date", and also that the current beta doesn't work with 433. So upgrade seems not to help - or?
When is a working beta planned for release?
Mats
Mats
Let's try once more.
You need to upgrade if you want your Oregon to work.
But if you need to add some 433 receivers, latest beta is not enough (the previous ones were, but the latest is not).
Therefor, you have 2 choices:
- or you contact support to put the correction on your box
- or you can wait for the next beta release.
The date of the new beta release is not yet known
