i cant save configuration change in fibaro devices
i cant save change of configuration in some fibaro devices . just change with use of api. and some devicea gi frequently offline
solved. .... i try to set temperature correction value on fibaro fgms sensor and for a bug web mask after insert difference of value, report a degrees gap and lock alla save operation. need only delete gap degrees reported on web mask and i can save again and device work fine.
