Zipato control center
I use the Control center, but the Interface of this program is horrible, i am electrition in norway and have used program for knx etc, but this Interface is not useful at all, its lagging and it is more beauty than useful. can you People go back to the old Interface that worked proporly? this is not working for me. it is a big problem for me , that a Interface you should pay for and its not working, you should work on this program so the Interface is more useful and more practik. please make this as a consider.
https://my.zipato.com/zipato-web/Dashboard, this is the old inteface. good luck
hello
the libk you sent me, is the New Version of webinterface. Please send me another link.
hello
@Tor Erling,
I just tested he link provided by Adrian, and it is definitely not the new GUI :-)
@Tor Erling,
Please,
It is not recommended to experiment with the old UI. If you're unaware of what you're doing, you might cause harm to your system. Proceed with caution.
V.B.
Please,
V.B.
it will redirect you to the new ui, check your web browser, just reenter it again. But as Vedran says, it is not recommended anymore as their programming of the zipato system has changed since this ui was used. "If you break it, you buy it my friend" be warned, it may cause more issues than help.
