Use Zipabox with Zibase for Somfy RTS compatibility?
Constant GIRAUD shared this question 13 years ago
If I buy a Zipabox and a Zibase, can I use the Zibase via Zipabox as a controller for my 4 roller shutters RTS Somfy ?
If it is possible, how? And will I loose information or possibilities with that?
I really want to use Zipabox but Somfy RTS is a problem...
Thanks for your answer!
Interesting idea:-) Certainly, you can do this if Zibase has an option to trigger some action in case of receiving http request from the Zipabox. Anyway, I think it is a waste of money as Zibase would be very expensive solution for this issue.
As you noticed already, there are many people voted for the "supporting somfy idea", so we are now considering the best option. We are finishing the whole bunch of the new features and new expansion modules which we need to publish during the April and May, and afterwards, we will solve this issue with the Somfy support. Most probably, you can expect this to happen before summer.
Great, thanks for your answer. Actually the cost of zibase without license is almost the same of 4 fibaro modules so it's not totally stupid ;)
However, if you can provide me direct access to my somfy roller shutters with zipabox it would be better and cheaper of course!
If you said it will be supported soon, I think I will take the risk and go with zipabox directly, I could wait a few months :)
