Virtual Thermostat for AC is not working
Abinav Shankar shared this problem 10 years ago
After the new update the Virtual Thermostat is not working for changing the AC temp through IR Extender.
Also the IR Extender the IR codes jump when trying to select the correct company.
Does anyone have a solution for the same.
Learning the codes is done but changing the temp through Thermostat is better
