Date comparison bug
David Pritchard shared this problem 10 years ago
I've reported the following bug to Zipato. I'd be interested if anyone else has experienced this.
I've found that the standard way to compare with a range of dates doesn't work. If you use the (Date x between y and z) variable piece, the comparison fails. But if you use a standard between operator with (date of (now)) and two dates, it works. In the attached screenshot, you can see three tests, the last two being date range comparisons. Test condition 5 is set to "on", but test condition 8 is not. (Today is 19th August).
Good to know Dave. Thx
Thanks for sharing.
I have wasted some hours on this myself. See here for Zipatos explanation of the difference between time and time_of (last post in the thread)
https://community.zipato.com/topic/the-logics-of-set-to-truefalse
Not very user-friendly and impossible to know in the first place
I still don't understand the difference after reading the explanation, unless they mean that "time of" is used with a variable containing a time value...? That would be nice if it worked, but I tried to use it and gave up. Maybe I should give it another go.
In any case, both of the "between" options should work in the same way, surely?
This now seems to be working with 1.1.38.
