How to program scene buttons on Zipatile
Guest shared this question 10 years ago
Any guidance on how to program the scene buttons on the Zipatile ?
Thanks !
Greetings,
You can use the touch manager application to assign certain actions or applications to scene buttons or touch gestures.
But if you need advanced functionality you should use the rule creator. You can find plenty of documentation about the rule creator in our knowledge base.
yes, on the tablet itself is an app called touch manager. This will allow basic functions like open an app, run a scene etc. But for a more detailed application use the zipato rule creator. In the block section you will use the sensor puzzle and in the devices go to the control tab and select the touch events device. Then you will see all the different available options for both screen swipes and touch buttons
Hi there,
Thanks for the enclosed. However the touch manager provides options to start an application, turn on/off the screen, but does not have an option to run a scene.
Thanks,
Donal
For that you need to use the rule creator. Insert into a sensor puzzle the correct piece and voila.
