Virtual thermostat
It is in any way possible, to get the Virtual Thermostat under 5 degrees????
Use the "virtual Thermostat" in a greenhouse, where I want to be able to control it around 0 degrees.
Hope there are some that will help me, please :-)
One possibility would be to increase the measured temperature.
Create a virtual thermometer greenhouse-v, and put it as the thermometer in the virtual thermostat.
Then create a rule.
>IF temperature greenhouse
>Then temperature greenhouse-v set to Temperarur greenhouse + 10
if you set in thermostat now 10 ° C,which corresponds to 0 ° C in the greenhouse.
regards Maik
Then create a rule.
regards Maik
