Problem with rule "WHEN clause has no event dependency"
Alberto Macias shared this problem 10 years ago
In Progress
Can someone tell me what is the issue with this rule? When I try to save I get the error "WHEN clause has no event dependency". I'm trying to run a scene every hour during a certain schedule, I have a variable that its turns ON for 15 seconds, every hour already, and want to use that variable to trigger this rule.
The problem is with the variable in the when puzzle. I just tried the same and same error. You should replace the variable with a virtual sensor or other virtual device.
Im not sure if this is fine, but currently the only way to do. Looks like variable cannot trigger a rule.
Thanks, that's what it looks like but it sucks!!
So basically variable is not good for everything. Definitely not for triggering a rule.
Dear All,
We will do our best to resolve this issue as soon as possible and we will keep you informed about the progress through this topic.
Thank you for your patience.
Pero Zovkic
Thank you Pero.
