Presentation of devices
Peter shared this idea 10 years ago
Consider a multisensor with an attribute cluster with two attributes: temp och lum.
Temp is configured as type "temperature" and "show as device" enabled.
Lum is configured as type "luminance" and "show as device" enabled.
The point is to have each sensor under the right category in the device browser.
The problem is that the label will be the attribute name. It would make more sense if the attribute cluster name or end point cluster name could be used as label instead.
1dd5e33903d20c09b29cb6248dec2c97
