virtual switch values are not what the web control app indicates
Today I had to disconnect my zipabox from the internet while I installed an UPS.
After I connected the router to the UPS the internet connection came up again and the Zipabox LED went to steady green. So far so good.
A short while after I noticed that some virtual switch values were ON in the WEB interface but the rules that checked these virtual switch values reacted as they were OFF.
I know that virtual modules are stored in the cloud but that means that the zipabox does not work properly in standalone (= not internet) situation. This could also be a potential risk in healthcare!
Please move the virtual stuff (switches, meter etc.) from the cloud to the box.
Cheers,
Frank.
Frank,
As far as I know, also the virtual devices are hosted on, and run on, the local Zipabox. I guess you can easily verify this by creating a virtual switch which changes its state when a door sensor or whatever is activated, and where the virtual switch thereafter changes a light - and testing this with your network cable disconnected.
I bet you will find that what you saw in the web control app, was whatever was there before the Zipabox was rebooted, and which wasn't automatically synchronized with the Zipabox again after the reboot.
Brgds, Robert
Frank,
Brgds, Robert
