Zipato API Device Action ??
Allan shared this question 10 years ago
Hi im new on json code and just playing with the zipato api interface.
there is a device action send command where you put in the uiid of the device and send the command to the device.
I just want to send a off command to a on/off switch but off do not work any who know what to type instead?
and do anything needed in the body table also.
I figured this way of doing it>>
1- go to device manager.. go to the device you want to control .. search for an attribute
(for example: I'm using a Zipato Micro-module Switch double , to turn the switch on you need to look for "State" attribute)
b92e36d871e57ecfac3069b533e2f294
2- click on configuration Icon
3- copy the UUID
4- Go to API >> attributes
c5976631ff363b37236e7f13bc5f9144
this will make you able to turn the light ON/OFF from API page
you can do it also using an HTTP request from your browser or any where else
Same problem, where can we find the documentation for the API?
3- copy the UUID
3
How does the "URL" look to use it directly in the browser?
Although Allan's original request was not the function of the API command in question, we still do not have an answer to how to properly use the "/devices/{uuid}/actions/{action}" API? The API test screen does not say what valid "actions" are and it is a required parameter.
