SIREN ON DOOR LEFT OPEN
Michael Haller shared this idea 9 years ago
I have a ZipaBOX and a 3in1 Zipato sinsor. I am trying to right a rule that allows me to pass through the door and within 10 second nothing happens. But if the door is ledt open longer than 10 seconds the siren will go off. Then the siren turns off when the door is closed (Contact)
Please help. How to I right this rule?
Thank you in advance
please see attached screenshot - maybe my solution can help you
THank you so much for your help.
Now how do I tell the siren to stop once the door is closed
try to make:
WHEN <<DOOR ANY> AND <SIREN ANY>>
IF <<DOOR CLOSED> AND <SIREN ON>>
SIREN ACTION OFF
You have been amazing. I'm sorry to bother. I am also trying to get the ambulance sound to toggle on off until the door is closed.
Also a rgbw light to turn blue after 60 seconds and remain lit until the door is closed. This is for a hotel rear access door that should not be kept open.
Do you know if there is a way to lower volume on the chime?
I would call the manufacture for help but it's a foreign number and this is new to my vendor as well.
try to find manual of your device
basically you need copy/modify my rule and
You can set an ACTION on your SIREN to TOGGLE IF DOOR is OPEN
for RGBW you can set an WAIT 60 SECONDS then an ACTION RGBW (pick blue)
and a ACTION GOTO 100
if need more help you can always submit a ticket
or you can ckeck https://www.youtube.com/user/zipatotv/videos for rule creator and knowledgebase https://community.zipato.com/knowledge-base/article/%E2%80%8Bintroduction-of-zipato-rules-creator
