Multiple binary inputs to Zipabox?
David Crump shared this question 10 years ago
Hi All,
I'm new to Zipabox, so apologies if this is an obvious question.
My Zipabox is right beside my security alarm, and I would like to pick up the PIR and door sensors and use them as binary sensor inputs into the Zipabox. I have a total of 9 door and PIR sensors.
I know I could use Fibaro Universal Sensors, but I would have to buy 5, making it pretty expensive. Or I could get the alarm module, which would give me 6 inputs, and I'd still need two Fibaro modules..
But given that the Zipabox and alarm are right beside each other, is there any good way of doing this as a hardwired input?
Thanks in advance,
Dave
Well, you could ask if the zipabox can work with two security modules attached...
Hadn't thought of that. I suppose that may a possibility, although pretty much cost neutral compared to the one security module and two Fibaro universal sensors.
Does seem a pity to pay for another whole security module just to use a small part of its functionality.....
I dont really thing 2 security modules can be used in one box. Zipato supposed to have a security expansion module that would allow more than 6 zones to be wired, however I dont think it is out.
Should check with Zipato is this is your plan.
actually I think 2 can be, used but Attila is right, check with support first. Or just group a couple together.
I feel that I am talking a lot about the Z-uno without even having tried one myself :-)
If I understand this right, though, you might be covered using a single Z-uno. You will need some basic electronics knowledge, programming skills and a soldering iron, though.
https://z-uno.z-wave.me/examples/Certified10Channels/
Thanks - interesting suggestion,
Not sure I tick all the skill boxes, but that has never stopped me from having a go.....
Cheers,
Dave
