Geolocation with LOCATIVE ???
Does anybody use locative for Geolocation ( https://my.locative.io/ )
I wold like to see the script witch turn ON/OFF virtual switch.
Please.
TNX in advance.
P.S.: IFTTT reliability is very poor.
Are you using iOS?
I'm using this solution:
http://www.domotica-blog.nl/post/geo-locatie-tracking-automateitapp
(android)
Are you using iOS?
(android)
I am really happy with the use of Life360 combined with IFTTT/Maker notifying virtual sensors/switches in Zipabox. It's very accurate and I have yet to experience failures.
I did use IFTTT with IOS Location, but I was disappointed.
U can save only two locations to Live360 , unless you take the premium version ???
I have setup up now Life360 with IFTTT - have to test it ...
Life360 in the free version can trigger reports for two location (geofences). I guess one only need to connect one location (at home) to IFTTT->Maker->Zipato. Unless, of course, someone wants to complicate matters and e.g. have a geofence around the spouse's workplace, changing the RGB-lamp in window to Green when the spouse is at work, signaling to the lover that the coast is clear, and trigger an audible alarm when the spouse leaves the workplace.. That too would be covered by the free version of Life360. Adding a third geofence which triggers when the drives around the corner a few blocks away, would require a paid subscription :-)
I need to find alternative solution as Tasker for ne is not reliable enough. I experience too many time wifi disconnection (I guess its either my phone or my wifi router) and I had to turn off my automatic arming.
I will need to give this a go - Robert has usually good ideas.
