Problem with the transmission of camera Zipato!!!
Live broadcast of the camera only works on the same network
I can not see on the Zipato application in the camera online
I can not add more than one camera Zipato in Scan in zipabox, why? only for add for IP (even though Zipato cam).
how can I resolve this problem???
Please help me????
Please help me????
Willias,
If your cameras are zipato cameras I would suggest you to open a ticket on zipato support. Also I noticed you are using 1.1.23 firmware which in my case was causing issues with Zipato Multi Sensors 4 and Aeotec Multi Sensor 6, not sure if this would be the same case but I had to revert my zipabox to 1.1.17 to get it to work.
Regards.
Willias,
Regards.
Alberto Macias thank you !!
how do I revert the firmware 1.1.17??
Willias,
See attached screen shot, you have to go to controller settings and load the last official firmware. Please be aware that you are updating the firmware of your controller, please do not disconnect the box while performing this procedure.
Willias,
Same issue with 1.0.17 with my system. Live stream will works in the local network with a tablet, but not with the browser chrome (?!). Further no stream via mobile phone and mobile network. But with the foscam app everything is fine (no data rate limitation)
Problem solved with cameras.
