Buttons on Ziptile to turn devices on/off
Stephan H. shared this question 10 years ago
Dear Friends,
is there a possility to use the Buttons to turn on/off devices? What do I have to do? Can anyone ost some examples?
Stephan
Just use it in the rule creator.
The buttons are available as input devices and can be used to trigger events
There are some examples available in the forum already
It's very easy and intui
Thanks - can you post an example for the internal led Buttons or a links
Thx
Stephan
Stephan,
Try something like this. Zipatile buttons are found on Control devices and you can put any action you desire within the When condition.
Regards.
See my two rules. The light switch is similar to Alberto§s. The dimmer rule is a bit more complicated, but what it does is tho basically toggle the two light. If the two lights are not synchronized, it synchronizes the two lights and then simply toggles.
Attila,
I am curious: Why do you have <STOP> commands in these rules?
Brgds Robert
Perfect - Thanks!!!
