Climate choices in rules creator
I have some problems creating a rule with climate thermostat, some choices are obvious, other ones are not (for me). This is what i understand :
- Auto - It is supposed to make temperature been ruled by widget but it ask something more after
- Cool - I suppose, it launch cooling system at a temperature choosen
- Heat - Same than above but for heating system
- Hold - Keep the temperature actual
- Hold until - Keep temperature until next programmed change in widget
- Mode - Help me with this
- Off - This choice has obvious sense )
- Preset - Need help for this
- Value - And so this one
Can you please give me more light ?
same question, no response
hello,
any answer for that? I want to change the status of the climate control (comfort, away etc) with a rule. I think that I should do thais with "mode", but do not found how.
hello,
