Problems with my z-wave Remote !!
I have a Z-wave REMOTE all what I try to create using the control does not work I've tried using it in some situations and came to nothing Anybody know how can I use it???
You need to include it in the rule creator to trigger the rules. If you want to use it for alarm, you will need to assign it to a specific user (each buttom separate).
As you can see attached It is already included even then all rules created does not work.
I see nothing attached besides a picture of the remote....
Greetings,
Make sure configuration option 7 is set to 1.
Greetings,
Greetings, Marko Katic
could you show me An example configuration in option 7 set to 1???
I'm not managing to attach no image!
Willias,
Once you added the control to zipabox/zipatile go to device manager and click on its settings (little gear icon), then use the custom configuration area to add the following settings.
Make sure you SEND the configuration to the controller and when the interface says "Please wake up your device" you need make the wake up procedure .
Willias,
Thanks a lot for the help!!
