Inclusion of Modules does not work
Raffael Schnell shared this problem 9 years ago
Module inclusion on Zipatile (e.g. Qubino Roller Shutter) is a nightmare. With lots of pain I've managed to get a qubino roller shutter module working (including venetian blinds mode). After this test-drive I've installed 9 pieces in a wall box (3x3) behind the normal switches.
Sadly now I needed half a day to get a further module working (hard time to include the module), now inclusion seems not working at all (the circul just turns and turns and the count-down does not start). I also have the impression that there are sync. problems as over the web I see ocasionally different settings and just after time-consuming synchronisation things are again in line. After more than a day spent and just 2 Modules included I'm close to give-up. I'm just having the impression this is a not mature product!
Does Zipato has any ideas how to improve the situation quickly?
BR
I had the same experience. Sometimes the same device (433 Mhz) would include right away, and then again it would completely refuse to join for endless attempts. Now, that I have finally everything included I need the box refuses to synchronize ...
I am not a happy customer at this time.
Dear guys,
please open a Ticket at support.zipato.com and provide us with the serial number of your Zipato controller so we could examine this case. Thank you in advance.
Pero Zovkic
Hi Pero,
Thanks for the response. The synchronization works again (see other thread, I have asked for the ticket to be closed). For the time being, I do not need to include more 433-devices, but I will get back to you if the problems reoccur (I understand that they are quite common).
Kind regards
Tim
I had same problems today (no sync possible; impossible to include new devices (just the turning circle with no countdown)).
After all login to my.zipato.com is impossible since 30 minutes (404 error).
Best regards
Guido
