Set an offset to a Danfoss LC13 setpoint
Luca shared this question 9 years ago
Hi, in my house I have 8 Danfoss radiator valves LC13 controlled by a virtual thermostat.
One of them is getting a bit too hot, so the room temperature is always higher than the others.
I would not create a separate thermostat just for this radiator, so I'm trying to set a sort of offset for this valve.
In the danfoss manual, I can see that this zwave command is supported: "COMMAND_CLASS_CLIMATE_
CONTROL_SCHEDULE
Control a temperature offset to
the thermostat setpoint of living
connect®. The temperature offset
is defined by schedules and
schedule overrides."
If I understand correctly, setting this parameter should set an offset for the valve, e.g. setting -2 should avoid the radiator to become too hot even if I leave the same setpoint coming from the virtual thermostat.
Is someone using this parameter?
Have I understood correctly its function?
you can set an offset directly at the device. See manual. If your device is too hot, you can change that. There are 3 levels available.
Are you refferring to P1 P2 and P3 settings?
yes
