Monitor temperature with Fibaro motion sensor
Bjarne Saltbæk shared this question 9 years ago
I want to monitor the temperature in my living room with the Fibaro FGMS-001 Motion Sensor i have there.
I have created the following rule that should send an Apple Push message to my ipad. But nothing happens.
Can someone help me out please?
f2f405ab2e2b93d8c10673ea6a4be741
302604ac68b12c70a4fa14750cc9e1e0
Bjarne
I don't know why even the "Temperature" option is selectable on a SENSOR puzzle. You need to use a METER puzzle, see attached.
Yeah, I see your point.
9ac879d09e2d5935c2e62dd42f8dda3d
Now the new rule works, sort of. Alarm is triggere. But variable templiving is set to True and not the measured temperature. Any idea how to transform that from the motion sensor?
Bjarne,
Same issue, you have to use METER puzzle. SENSOR puzzles and sensors only give you a binary state (which again, I don't know why a meter can be used as on a SENSOR puzzle), METER puzzle (rounded) gives you all the information that the device can send. See attached.
True again. I just came to same conclusion :)
959d818390c0a25893a6b20e21a2137b
Now i just need to trip that value. 20.2000000987987978 looks a bit messy.
54ff334c051fe68f32254d3e43f50224
If you don't mind me asking, why are you storing the meter value on a variable? are you using it on other rule? otherwise it doesn't make sense to do that, you can use the same meter attribute on your message. That will get rid of all the extra decimal numbers.
I want the current value included in the push message to me.
You don't need to store the value in a variable to do that. Use the corresponding attribute from the desired sensor/meter, see attached.
Aaah neat Alberto. Thanks a lot :)
(facepalm). I hah not seen the scroll down bar in the Attribute box :D
No problem, It happens. Glad I could help.
