Access to a device in a different network
Eduardo Corraliza shared this question 9 years ago
Is it posible to include in the Zipato system a device out of the network where Zipabox is connected. For instance, if the alarm in my office detects and intrusion by night I would like to listen a siren in my house. Not a phone notification but a siren so I know that something is happening and I can check my CCTV system.
Many thanks
of course, all you need is a connected siren at home. The Zipato at office can send a http request to your home network. You can do this by many different methods, but it depend on the siren you have at home and how it is connected and with what.
Many thanks for your quick answer. Does connected sirens exists? I mean, not a siren connected to a domotic system as Zipato but an autonomous connected siren able to receive http requests. Thanks!
You could even just buy any 240v siren and use a belkin wemo plug. There are a ton of options just using a WiFi enabled plug or controller module. Just be sure you can use simple url calls or IFTTT channels.
I will try, many thanks!!
OK, many thanks!!
What about creating a rule to turn on an actuator monday to friday at a time and turn it off same days at a different time? I'm trying to do it with the shutters and it doesn't work and getting crazy... thanks in advance!
just create 2 rules. 1st rule use the scheduler to set the time and repeat days to turn on the actuator, then 2nd rule do the same to close. see "1" attached. Then later you may introduce other factors such as "2" where it only turns on if the light level is below 20.
Great, many thanks! Will try and will let you know the result.. many thanks once again.
It doesn't work! What could be wrong? (picture attached with rule). Thanks!
It works! The thing is that I don't know why it takes the GMT time but not the CET time (mine). So 1 hour later it worked. Thanks!
