Zipato Android App - white?
Ian Hammond shared this question 9 years ago
As it is possible to have the Zipatile UI in white, is this also going to be possible on the Android app? I am assuming they are very similar?
Replies (7)
Hi Ian,
How did you manage to get the Zipatile UI in white? I only managed to get the App Repo in white - but not the main app.
BR
Raffael
Hi Raffael,
I dont have the UI in white. If you look at the pictures of the Zipatile online, you can see the UI in white so I am assuming it is possible to change the colour on the Zipatile somehow - so would assume it should also be possible on the Android app?
Ian
all we see in the adds i snot availabel "yet" for instance try to move some apps in the shortcut area...
Ok, the white I've also seen just in adds. Then I assume one can't change the background to white yet. However I would not call that on the top of my personal priority list for open items with Zipato ;-)
I am sure there are people on here who have the white Zipatile - can any of them confirm the white UI on it?
It's the same in white Zipatile, black app also
That's really quite bad because all the advertising shows it in white. In the UK that is called false advertising
I found another post that said you get the white UI by:
"You can do that by going to Settings - Accessibility - Color Inversion."
I found another post that said you get the white UI by on your device going to Settings - Accessibility - Color Inversion. But that messes up any camera feeds
As the screen is black when off anyway, I to don't really care if there is a white version of the app. In fact it may be to bright, but not to say a choice of choosing the background colour and text colour would be nice for some individual customisation.
Depends if you let the screen switch off - I'm considering a wall mounted always on device
Support advised me that the white UI will be available in Feb
