Level doesn't update in application - Qubino flush dimmer
I have a Qubino flush dimmer and if I switch on the light with the wall switch (mono-stable) the level will update in the application, as well as if I change dimming level. But when I switch off the light, the last level is still presented in the web control center as well as in the Android app.
Is this a fault in my qubino, a configuration issue or just a bug in the applications?
i´ve got the same problem with my philips hue bulls, but got no solution.
Actually my zipatile ist complete without function, no function home rules,+
i can´t even add a new device.
I Have the same issue, and on all my qubino dimmers (4) and from the beginning when I bought them. I have tried reinstall them many times without results. My reseller have opened an ticket about it but I dont know how is going. I bought my first dimmer 2016-08-08
I've noticed that the level is updated if I have the android app open when I'm switching off the light with the switch. But not when the screen is shut off.
By they way do my Everspring dimmer wall plug update the level when the if screen is off and I use the button on the plug to alter the dim-level.
I've got the same problem. Also is the cumulative consumption value not updating for all my qubino modules.
