Rule not save when I change scheduler !
domoteek shared this problem 13 years ago
Not a Problem
When I modify the scheduler time in a rule, I can't save it, the change seems not to be see ansf save link is not in red. I should Modifie anything else in the rule to save it, and put it back ti save it again !
Can you modify this, to enable saving when you only change scheduler time in a rule ?
Thank you !
Scheduler is saved separately, you don't need to save the rule after editing scheduler.
So there is a problem because when I change time settings on a scsheduler, the associated rule is not executed with the new settings but with the old hour settings. It seems that something is not updtaed correctly. Nevertheless, If I create a new rule with the new scheduler, it is working correctly.
OK Sorry, I have forgotten to synchronize when I made my last test ! It is wirking now !
Thanks !
