Entry and exit delay
aldesign shared this question 13 years ago
hello,
I have Fibaro sensor (FGK 101-107) on my entry door, I activate alarm whith Ipad App and I want 30 seconds delay on this sensor when I get home or I leave my house without ringing the alarm, how, I don 't happen.
I entered 30 seconds in entry and exit delay.
Replies (12)
Yeah, the delay is working when arming alarm from web dashboard but the alarm is immediately armed when it's done on the iphone/ipad app.
By the way, I have a zwave.me keyfob and it's the same for it, no delay when arming alarm.
Why not activate/deactivate The alarm outside your home?
Thank you for your reponse thomasfr,I don't want remote, nor activate/deactivate The alarm outside my home with my Iphone for all days, it's much more convenient such as keyboard, no need to out the remote control or iPhone of its pocket.
I have my Ipad on the wall in the entrance of my house to activate or deactivate the alarm, I move my door sensor Fibaro, I do not have a choice.
I have exactly the same problem. I need to activate/deactivate the alarm when i'm still home using the keyfob. It allows you to see if the alarm has been correctly activated or not (by using squawk function for example)
Delay issue is probably not related to the keypad, but to the delay in general. We will check it out...
Ok thanks,
Delais work fine with arming alarm with web site. The issue is with keypad.
I have the same prob. Have you an issue for this???
Same problem here! Any news?
I have set the Entry delay in "Partition Options", but it works only if I arm the alarm from WEB, if i do it with App or with "Mini Keypad" doesn't work.
What sort of tips are this? If I have a ZIPATO product like mini keypad why I cant use it to arm and disarm alarm? ZIpato doesn't support ZIpato products?
No news about arming delay with kfob or tags?
SAME PROBLEM!!! 3 YEARS AND PROBLEM NOT SOLVED!
Zipato not ansvering to my issue 2 weeks. VERY VERY BAD SUPPORT.
Are you sure? Are you running the latest firmware on your controller?
I thought this worked as expected. If you are having issues and it isn't working, try using the keypad to trigger a virtual switch or sensor which will trigger the alarm.
