After update IOS app to version 2.3.3 my Zipato hides imeadietly.
Jon Eriksen shared this problem 9 years ago
After updated IOS app to version 2.3.3 app starts but hides imeadlety. When start additional time hides again. New update wit fix are needed
Replies (18)
Poster this issue wrong the first time. Now reporter AS a problem.
I have the same problem. In the app store it says work with ios 8 and above.
On my iPad 2 is ios 9.3.5
I have the same problem!!!!!
we tested Zipato app with iOS10 and we didn't have any problems. Is there anyone with the same issue on iOS10? Also we will check what's going on with iOS9.
Thank you all for your information.
Regards,
Dominik
Is there any progress on this problem?
Thank You in adwance.
I have iOS10 on my iPhone there is no problem.
I have IOS 9.3.4 and have this problem
I hawe IOS 9.3.5 and hawe problem.
Yes, problems with 9.3.3.
Same problem on a iPad IOS 8.
233(60) on 10.2.1 runs like a charm....
Same here on ios9.3.5
How long could it take to deploy a new version that works under iOS 9?
Normaly Apple will released an app within two or three days!
Hi all,
we have tested the fixed app (fixed crashing on iOS9) on external testers, and they reported that the app is working properly. We submit this fix to Apple, so we are now waiting for them to approve it. This approval procedure usually takes couple of days.
Regards,
Dominik
Also having the same trouble with my iPAD and iPhone. My iPhone has a Version of 8.4 and the iPAD is 4.8.1.. I realize these are older versions but were working fine until the updates. Please advise.
Fix for crashing on iOS9.x.x is available on App Store.
Regards,
Dominik
Thanks for this - it fixed the app crashing issue on my iPad.
Cheers,
Dave
Yess now I can use Zipato on ipad again.
Jon
Thank you, i can use my iPad again.
Philippe.
