Qubino Whole Home Meter Simple no attributes in rules
Not a Problem
I've bought a z-wave module "Qubino Whole Home Meter Simple" and I can't use it in rules function. No attribute is possible (or visible).
The module is OK. I see all parameters in module menu : CUMULATIVE_CONSUMPTION, CURRENT_CONSUMPTION, VOLTAGE and other.
In the other side : in Imperihome, module isn't visible.
Best Regards
Capture d’écran...
It seems that the device is not yet supported - does not have correct descriptors.
You will need to raise a ticket with Zipato support on support.zipato.com
I bought this product mainly because I read in the advanced manual of QUBINO that was compatible with ZIPATO. After opening a ticket, I read in the forums that for months the problem exists and what I see does not solve it. QUBINO just told me that "they have urgent work" and I'm still waiting for a response from ZIAPTO. I consider myself scammed
Well, try to include it again. Remove from the netword, factory reset and reinclude. Some qubino§s take a couple of attempts in order to show up as desired.
I have exactly the same situation. I read on the forum that someone else has the Smart Meter and it's working in rules. Do we all have to go through support requests to get it working?? If Zipato put more work into reliability they would save themselves a lot of support work.
