Antenna cabel to ZipaBox?
HB shared this question 13 years ago
what kind of antenna cable should I use to move my antenna to zipabox to a more suitable location. How long can it be? other things to consider to move the antenna?
must move it. it did not work at all when I installed my zipabox although the cottage is max 12m and it was positioned in the middle of the cabin.
12m should covered with the standard antenna for sure. If you need extender, you can use any standard extender with RP-SMA connector at the end. We have some 80 cm long on stock, and using them when Zipabox is placed within a fuse box, covered by the metal door.
