Sensor Configuration Value needs to accept negative values
I'm running fibaro motion sensors and need to configure the temperature, so it shows the right temperature. According to the manual, there is a setting called 'Temperature Offset' which ranges from -1000 to 1000.
The Web control center just allows positive entries, which - at least in this case - is wrong.
Cheers
Never used this function but I agree, we should be able to use negative values. What I have seen on other devices that use negative numbers is that Zipato assigns a popup selection with a name so you can select it but when you retreive values it shows the negative number the controller really sent.
In this case I think negative numbers is the way to go. If you really need this I would suggest you to open a ticket on https://support.zipato.com/, login using your zipato credentials, explain that you need this option and include the serial number of your controller.
Best Regards.
Best Regards.
Alberto
Thanks for your fast answer.
Cheers
Alberto
Cheers
