livolo smart switch
does zipato support all kind of livolo smart switch (1 gang ,2 gang etc)
Yes it does but it is no good. It is not 100% because the livolo switches use a modulation type that is simply said not reliable. So not always when you send command it deceives it...do not build on these switches.
well..... I am using several Livolo switches, and to be honest, they work great. The only problem is of course they don't report their status. So if you want to make complicated rules that rely on the switches reporting their status, look elsewhere.... But just for simple on/off they work great.
I'have bought a livolo like on aliexpress.
It has been recognized by zipato like a livolo but on/off don't work ...
why ?
thanks.
why ?
thanks.
Not sure, does it show a UUID in device manager? Maybe delete and join again, they are sometimes a bit picky when joining.
also, you say "Livolo like"..... as in it isn't actually a Livolo switch? As this might mean they use a different protocol....
it's not a livolo. It's look like. it has been apparaid but don't work ... it has been recondinized by a chacon swith but on/off don't work...
can you show the link to this switch on aliexpress, and also a screenshot of the device in device manager?
this is it :
https://fr.aliexpress.com/item/EU-Standard-Smart-Wall-Switch-Remote-Control-Switch-1-Gang-1-Way-Wireless-Remote-Control-Touch/32691733140.html
this is it :
It most likely uses a different protocol. The genuine Livolo switches don't show a tab called associations. See below how they look like.
i have tried a lot of device but it doesn't work :(
you do indeed. :-)
you do indeed. :-)
