Intercom between Zipatiles under the same Cluster
Simon Matar shared this question 9 years ago
How to create Intercom between Zipatiles under the same Cluster?
The normal method is not working, each zipatile tends to create its own and not although the contacts automatically show on the Main Sip Server Zipatile, but you cannot make an intercom call.
The Sip server shows on the other Zipatiles as not ready and you can notice that the IP address is also the local one and not the SIP server Zipatile.
Make sure you have ZipaTile app at 1.2.15 or greater.
Please follow video tutorial for further instructions https://www.youtube.com/watch?v=SPdA5nfXOmM
If you have issues with configuration, please contact Zipato Support
We already did the SIP under cluster with the Tile that has the Pro license and it worked, but the other Zipatiles under the same cluster cannot call each other although they show on the contacts.
Please make sure that every ZipaTile is logged with cluster serial and they're on same WiFi AP / Ethernet network.
If they are not connecting afterwards, please contact Zipato support for further instructions
They are on the same Network for sure, already Alain has contact you for this.
They can be at same network but if they're on different AP then service usually isn' propagated to the another AP (more likely it is localizied per AP)
I doubt that.. they are on the same network, and probably some on the same APs. All are not working.
And that doesn't answer that fact why we have different local IP addresses service that they are trying to connect to, instead of the one that has actually the SIP server active.
