MICROMODULE SWITCH DOUBLE S1/S2 in charge
Manuel Rocha shared this problem 9 years ago
I've bought 3 MICROMODULESWITCH DOUBLE...
All of then the S1/S2 have 220v voltage... Is this normal?
According to diagram the voltage should come from switch and not backwards...
I have the same issue except using at 115VAC and that is what I measure on these two lines with nothing connected.
Hi there,
It seems that this is a normal behavior from zipato micro module. My issue was that I could not switch on/off the lights from the buttons, only within the app. This is because my house was three-phase and all the circuit should be on same phase (which on my case wasn't).
Is your home single-phase or three-phase?
Kind Regards,
Manuel Rocha
My home (USA) has 115VAC split phase. 230VAC with a center tap. So two phases of 115AC. Commonly called single phase.
My real issue is that I can not control the on and off state of this device using the S1 and S2 lines. I can control it with the button on the device and when included in the Z-Wave network. But applying 115VAC to S1 and or S2 with a switch just does nothing. I assume there is a setting that I need change but don't know what to change.
I'm not home now, but when I get there I will make a diagram on how you should connect the wires correctly on that case.
