Problem update firmware
Lafargue Eric shared this question 9 years ago
Since I upgraded the firmware (1.2.20) I can not receive sms.
Https://smsapi.free-xxxxxx.fr/sendmsg?user=20071587&pass=IZPLnrPFn7Kzqw&msg=overture porte garage
How to solve the problem?
cordially
Eric
Replies (28)
Same problem here!
there is not any of my HTTP get rules works
Here are a eksemple
I opened a ticket,
I advise you to do the same.
Eric
It's already done =)
just think that the forum should also know that there may be problems with the new firmware
John, please try again after changing the method from GET to POST.
That worked for me.
Roland
Realistically, that much power from pellets will cause some bruising, welts, or wounds to the exposed area. There are a lot of paintball players that just get used to welts and bruising in the intense paintball showdown.
@Roland K,
Unfortunately it is not possible
The API which I communicate with expecting an HTTP GET
John
Hello;
After opening a ticket zipato recognizes that there is a problem with firmware 1.2.29 but they still have not found the solution and do not even respond to my ticket.
I am very disappointed.
cordially
Eric Lafargue
Hello have you some news about that?
I need to send sms with free but i don't want to downgrad the firmware zipabox...
This fonctionality go work with the next firmware?
No nothing new.
I stayed with the software 1.1.38 and it works correctly to receive SMS from Free
Eric
Merci Éric, je vais voir pour passer en 1.1.38.
Il n'y a pas de quoi.
J'espère que Zipato vont faire nécessaire un jour.
Bonjour,
Idem chez moi, ils ont incriminés Free d'utiliser un certificat non valide, donc ce n'est pas de leur faute. Du coup je reste en 1.138, mais j'ai perdu ma sirène zipato dans l'histoire.
Bonjour,
Idem avec moi mais ensuite ils ont reconnu que cela venait de leur software et me disent rectifier la chose prochainement.
Mais quand ????????
La preuve c'est que cela fonctionne très bien avec le software en 1.1.38
Je pense qu'ils y bossent, car ils exécutent de temps un de mes script qui m’envoie un sms alors que jai effacé ce script depuis longtemps de ma zipato . Mais vont ils y parvenir ?
Quelqu'un a essayé la beta 1.3.5? On sais ce qu'il y a de nouveau?
Someone try the bêta firmware 1.3.5? Wath new in tous version?
Non
I try the beta firmware 1.3.8. I have the same problème. No news from people of zipato???
No news
Can you keep us informed if it works with the firmware 1.3.8 ?
Salut Eric, ça ne marche pas avec la 1.3.8....
Plus personne ne s'en occupe je pense... Zipato bloqué peux être car ils veulent vendre leur crédit pour les SMS...
It doesn't work on firmware 1.3.8. I think that this probleme is not under consideration yet.
Avez vous fait un ticket ?
Bonjour
J'avais ouvert un ticket sur ce problème il y a peu de temps. La réponse : "Their SSL certificate doesn't match the standards anymore as they haven't upgraded.Those requests won't work anymore until they upgrade and register for a new certificate"
Curieusement l'api free fonctionne parfaitement dans le navigateur et je crains de la mauvaise foi dans la réponse.
IL ne reste plus qu'à contacter Free mobile ce que j'ai fait. Mais les opérateurs de la plateforme d'assistance chargés de répondre ne comprennent rien au problème et font des réponses types apprises par coeur qui n'ont rien à voir avec le sujet........
Quelqu'un peut il prendre le relais aupres de free mobile ?
Bonjour,
Cela vient de Zipato car chez moi les sms via l'api de Free fonctionnent avec une ancienne version de l'url firmware.
Je vais ouvrir un nouveau ticket car le mien a disparu de leurs serveur :(
Je viens de créer le ticket avec les explications nécessaires et suis en attente de réponse.
Salut,
Des nouvelles de zipato? Pour info un nouveau firmware est sortie la 30/01/18 1.3.9 je ne l'ai pas testé car maintenant il ne sera plus possible de repasser en 1.1.38 le version qui fonctionne avec free... Quelqu'un de dispo pour juste tester et qui n'utilise pas les requête free?
Hello, News from zipato? For information a new firmware is released on 30/01/18 1.3.9 I have not tested it because now it will not be possible to return in 1.1.38 version that works with free ... Someone available to just test?
Bonjour,
Je suis intéressé également par la réponse.
Eric
Voici la réponse de Zipato
Hello Eric,
This is a very isolated user case so it's not top priority and we are in the middle of a new services development and roll-out so this issue got a little sidetracked . We will create an account and test it hopefully next week, see if it can be fixed and report back to you.
BR,
Mislav"
Merci pour le retour Eric, tu crois que je devrais aussi ouvrir un ticket?
il n'y a pas de quoi.
Oui tout à fait car d'après eux je suis un cas isolé.
Bonne soirée.
Ils m'ont aussi dit que j'étais un cas isolé après avoir ouvert un ticket...
Donc, nous sommes tous des cas isolés.
Ils abusent, mais je vais insister et plus nous serons mieux ce sera.
Bonsoir, je leur ai fait par du pb il y bien 1 an et ce n'est toujours pas résolu pour moi
Bonsoir;
Je pense que c'est voulu de la part de Zipato pour nous forcer à acheter leur abonnement pro.
Je n'ai toujours pas effectué la mise à jour de la box Zipato donc cela fonctionne encore.
Quand cela ne fonctionnera plus je vais remplacer la tablette de mon entrée par une tablette avec un slot SIM ou je vais y mettre la SIM Free et via MacroDroid je recevrais des sms sur le ou les smartphones de mon choix.
Perso j'ai monté en parallèle une box jeedom et la zipabox lui transmet les messages, ensuite c'est elle qui envoi les SMS.
A fur et a mesure des blocages de la zipabox, je migre vers jeedom tout doucement
I want to go back to firmware 1.138 because I lost the SMS FREEMOBILE SERVICE. How can I do this ?
Bonjour,
Je ne sais pas mais j'ai résolu le problème comme indiqué sur mon post précédent.
Bonjour, pour info, avec la dernière mise à jour 1.3.60 les sms free marchent de nouveau!
Merci pour l'info ... enfin une bonne raison de mettre à jour ma box
Cool pas d'autre souci après la maj ?
Hello! I just would like to give a huge thumbs up for the great info you have here on this post. I will be coming back to your blog for more soon. ball games
I think so,
The information you share is very interesting.
very nice information you share with us. thanks for this.
very excellent content this blog…..thanks
gmail login
The data you share is exceptionally fascinating.
extremely decent data you share with us. gratitude for this.
"https://apkjar.net/fyptt-apk/"
A socially conscious company committed to sustainability is LightOfSakina . For our clean-burning candles, we only utilize 100% vegan and cruelty-free ingredients, such as soy wax sourced ethically and eco-cotton wicks. To lessen trash and the impact on landfills, we also provide a refill service.
