Alarm does not work
I have just bought a Zipato Zipatile controller and have added my devices (5 motion devices, 1 siren and 1 RFID. All devices are added to the Zipatile and I can see the on the Zipatile, Ipad and phone. The Siren also work when you make a sound test and I can arm the system from both Zimpatile and Ipad.
When I arm the system and try to "walk" into the motion sensors noting is happening.
When did I miss to setup. Any ideas?
Esben
did you set exit delay too high maybe?
you also need to create zones, where you can specify which detector does what etc.
I'd like to see from Zipato detailed manual on handling alarm zipatile.
did you select your siren as the siren in screenshot 1?
Can you make a screenshot and share?
