Alarm does not work
Esben Henriksen shared this problem 9 years ago
I have just bought a Zipato Zipatile controller and have added my devices (5 motion devices, 1 siren and 1 RFID. All devices are added to the Zipatile and I can see the on the Zipatile, Ipad and phone. The Siren also work when you make a sound test and I can arm the system from both Zimpatile and Ipad.
When I arm the system and try to "walk" into the motion sensors noting is happening.
When did I miss to setup. Any ideas?
Esben
did you set exit delay too high maybe?
Hi Darkwing
Where is this switch located?
I have only included all devises. I am not sure what is next step,
See below, though this is Zipabox, so may be different then Zipatile:
3a70673bc54b2eac771987a6badf3769
f92342f4fef56eddc5eec8597c444cd6
Done now.
you also need to create zones, where you can specify which detector does what etc.
Where do I set this up?
be745a4c06fee36b9a86cb274b1b8895
4bee0d6afb834efe333c24bb35e0950c
Hi again Darkwing
Sorry for being so heavy, but I still don't get it to work.
When I arm the system, there is no sound from the siren.
You need to set the internal siren as a squawk device. Open the alarm settings and add squawk.
Hi Attila
Yes, I have set the internal siren as a squawk.
I don't know if you got my screen shoot
I got it now.
Still no good
I'd like to see from Zipato detailed manual on handling alarm zipatile.
Hi Pravoslav
I can't find the manual anywhere and it was not included in the box.
Sorry, there is no manual right now but the knowledge base is getting better steadily.
https://community.zipato.com/knowledge-base/articles
I hope there will be a manual one day, but I think with so many changes and developments going on it would be a nightmare to keep such a manual up to date.
But normaly you will get help here in the forum or, if no one has a clue, via the ticket system.
Klaus
did you select your siren as the siren in screenshot 1?
Can you make a screenshot and share?
Can you see my screen shoot. I can't see it my self!
I can't see it!!
also, did you synchonize your system?
Yes. I synchronise all the time. I just do it from my computer, so I expect it will synchronise with the Zipatile also.
best to open a support ticket at https://support.zipato.com/index.php? provide them with your serial number and they will be able to help further.
I will. Thanks Darkwing
There is a youtube video on the virtual alarm setup. Also in the knowledge base all info is detailed so should be ok. I used to read it when I was a beginner. Obviously time will help you to get better at it.
Thanks Attila. Will do.
