My Schedule doesent work
Finn shared this question 9 years ago
Something wrong for my Rule with Schedule my thermostat?
It doesn't continue to set the temperature - only in that moment I activate it. For example at 22:30 it doesn't go to 17° unless I switch Of the rule and then On again. So if I manually switch Off an On 2 times a day it finds the right temperature.
How to set it for automatically changing temperature?
All the "Send message" is only for my self, trying to find the error. I try to set 2 different scenes - weekdays and weekends.
Dont put a SCHEDULER in an IF block.
I would make two rules. One for weekdays, and one for the weekend. You can even make four rules, if you want the rules to be simple. See below:
Rule 1:
  1. WHEN {SCHEDULER weekdays 16:00}
  2. danfoss SET TEMP to 20
Rule 2:
  1. WHEN {SCHEDULER weekdays 22:30}
  2. danfoss SET TEMP to 17
Rule 3:
  1. WHEN {SCHEDULER weekend 9:00}
  2. danfoss SET TEMP to 21
Rule 4:
  1. WHEN {SCHEDULER weekend 23:00}
  2. danfoss SET TEMP to 18
If you want only two rules, this could be an example (there are more ways to do it):
  1. WHEN ({SCHEDULER weekdays 16:00} OR {SCHEDULER weekdays 22:30})
  2. IF { TIME NOW BETWEEN 15:00 AND 17:00}
  3. danfoss SET TEMP to 20
  4. ELSE
  5. danfoss SET TEMP to 17
Please note that your Danfoss thermostat has a wake-up intervall. So it might take some time for the new temp to be submitted (up to 29 minutes if your wake-up intervall is 30 minutes).
You need 2 if and no else i think
Sorry I don't get how to do it with 2 IF. I need 4 settings as I see it. 2 for weekdays and 2 for weekends.
Can you try to explain a little more pedagogically for a beginner :-)
The IF/ELSE block of your scheduler configure must be deleted and replace it with 2 IF block
Hi titof174. OK know what you mean. I will try it sometime, maybe I can use it in another situation. But for now it works with the example Jan had come with. But thanks...
Rule 1:
Rule 2:
Rule 3:
Rule 4:
  4. ELSE
Thanks - now I know that Scheduler and IF block is no go. It works for me now, with the last example you suggested.
