Reverb sign-in don't work
Tino Hildebrand shared this question 9 years ago
As mentioned in the ota threat, somehow there is no possibility to login.
Anybody figured out on how it works?
Thx
Replies (7)
There is an issue with the license certificate. We will publish the new version with the fix soon.
Perfect :) thx
a new version of Reverb is in the AppRepo.
When trying to upgrade, an error appears telling me that the new version is with an different certificate and that i need to uninstall the old one first. When trying to uninstall (As shown in the Zipatile instructions: App View -> Hold App -> move to uninstall area) only the "App Info" area does appear. No "Uninstall" Area. I tried with different App (Doorbird) and the "Uninstall" Area is shown up. Trying Reverb again, no "Uninstall".
So i can't install the the Reverb update.
Any idea (I have to say I am not at all a expert on android, as i have Apple only - Zipatile is my only Android device)
Thx guys :)
Tino
Unfortunately, since the Reverb app is part of our initial package, we will have to upgrade the firmware in order to fix this issue with the Reverb app. On Monday we will publish the new OTA upgrade with the new Reverb version, so it will work properly after upgrade.
good news :) thx Sebastian!
The new reverb 1.1.15 will apparently only install when the old reverb is first uninstalled. Who knows how to uninstall reverb? (or other pre-installed apps for that matter).
Goodnight.
I installed the new OTA.
I have a problem, every 2 minutes or so, in the upper left part of the screen, a message appears with a symbol that says "disconnected" then returns the symbol of "V"
Any ideas ?? Attached images.
Also every 5 minutes turns on and off the screen.
Greetings and thank you.
What OTA version did you install? V1.0.6. or V1.0.7?
What you describe was introduced with V1.0.6 (continuous disconnecting of "intercom"). If you installed OTA V1.0.7 then I guess this is not fixed yet (and will my current download of OTA V1.0.7 be another frustrating experience).
Hi, Ronald.
I downloaded and updated the latest OTA available today, V1.0.7 in my case it follows exactly the same as with version V1.0.6 that gave the same problems.
I'm not sure what the problem is.
Greetings.
New version of InterCom application which resolves "Disconnect" issue will be available today via AppRepo.
Hi.I can not see appRepo anymore. Now i only see an icon called F-droid. It is normal?. I have the same problem reported by francisco and i still do not see any updates on that F-droid.
Greetings.
Hello Andres.
I am also the same, the support service told me to force the intercom output, to stop connecting constantly, but that does not work, everything is the same.
I also noticed the repo app, now it's f-droid.
Greetings.
